Using LuaCOM to Control Microsoft Word and Microsoft Excel
Use a Lua script to generate Microsoft Word or Microsoft Excel documents with specified content without having to open the applications.
Use POSTFEKO to validate meshed geometry and analyse and post-process results.
View the main elements and terminology in the POSTFEKO graphical user interface (GUI).
POSTFEKO has various default settings that you can configure to customise it to your preference.
A number of rendering options are available to ensure that 3D models and graphs (containing a large number of sample points) are rendered efficiently.
You can add a model, open an existing project and save the project.
Import text files, native data files and Touchstone format files.
POSTFEKO supports the export of native file formats. These files can be exported to use in other sessions or when further post-processing is required.
The terms, dataset, slice, trace and 3D result, are used extensively in the documentation. Review the definitions to get a better concept of these definitions.
Display result data on a graph to allow visual interpretation of the data in a human-readable format, as well as to communicate the results in reports and presentations.
A Cartesian surface graph is a flat colour plot with results plotted against two independent axes.
View the simulation data in a 3D view to allow visual interpretation of the data in a human-readable format, as well as to communicate the results in reports and presentations. The 3D view can also be used to verify that the CADFEKO or EDITFEKO model is correct.
The Solver contains a number of frequency domain solution methods, as well as a time domain solution method. By default, all simulation results are obtained in the frequency domain, unless explicitly using the time analysis tool in POSTFEKO to convert the results to the time domain.
With the time analysis tool in POSTFEKO, electromagnetic scattering problems can be analysed in the time domain. The time domain results are obtained by applying an inverse fast Fourier transformation (IFFT) on the frequency domain simulation results.
Use animation to obtain a better understanding of results or export the animation to use in a presentation or report.
POSTFEKO is a useful tool to help analyse and present data in a useful format. It is often required to use the processed results in a report or presentation. To help make it easier to generate these reports, several tools are available in POSTFEKO.
Export an image of the active view to file.
Generate a report with minimal effort using selected images and headers from a POSTFEKO session using a predefined report template.
Decide on a Microsoft template to define the theme, company logo and branding to use when creating a POSTFEKO report template.
Create a POSTFEKO report template when it is required to create consistent reports. The reports are generated from a preconfigured POSTFEKO report template using styling from aMicrosoft PowerPoint or a Microsoft Word template.
After a report template was defined, create a report using the report template.
A report template can be exported to XML format for reuse in another POSTFEKO session.
A report template can be imported from an XML file to reuse in the current POSTFEKO session.
Feko provides a powerful scripting language that allows you to create scripts that control CADFEKO and POSTFEKO.
POSTFEKO has a collection of tools that allows you to quickly validate the model, for example, measure distances, measure angles and finding specific mesh elements.
View the files associated and generated by POSTFEKO.
-- MS WORD require "luacom" -- Open Word local msword = luacom.CreateObject("Word.Application") assert(msword, "Could not open MS Word") -- Initialise the document msword.Visible = true doc = msword.Documents:Add() -- Add content insertionPoint = doc.ActiveWindow.Selection insertionPoint.Style = "Heading 1" insertionPoint:TypeText( "Feko Says..." ) insertionPoint:TypeParagraph() insertionPoint:TypeText( "Hello world!" )
-- MS EXCEL require "luacom" -- Open Excel local excel = luacom.CreateObject("Excel.Application") assert(excel, "Could not open MS Excel") -- Initialise the worksheet excel.Visible = true workbook = excel.Workbooks:Add() worksheet = workbook.Worksheets:Add() -- Populate the data and display the contents of cell A3 worksheet.Range( "A1", "A1" ).Value2 = [[hello]] worksheet.Range( "A2", "A2" ).Value2 = [[world]] worksheet.Range( "A3", "A3" ).Value2 = [[=CONCAT(A1," ",A2,"!!")]] feko.Form.Info( "Excel says...", worksheet.Range( "A3", "A3" ).Value2 ) -- Change an input value and display A3 once again worksheet.Range( "A2", "A2" ).Value2 = [[everybody]] feko.Form.Info( "Excel says...", worksheet.Range( "A3", "A3" ).Value2 )
