Altair Inspire Form User Guide
2022.3
  1. Home
  2. Parametric Modeling
    Create 2D sketches, surfaces, and solids.
  3. Geometry
    Create and modify parametric surfaces and solids.
  4. Extend Face
  • What's New
  • Get Started
  • Tutorials
  • Parametric Modeling
  • Feasibility Setup and Simulation
  • Die Face Design
  • Tryout Setup and Simulation
  • Trim Angle Analysis
  • Simulation Results
  • Reference
  • Keyboard Shortcuts and Mouse Controls
Index
2022.3
  • What's New
    Discover new features and enhancements.
  • Get Started
    New to Inspire Form? Learn the basics here.
  • Tutorials
    Start using Inspire Form with our interactive tutorials.
    • Global References
      Global references are the global origin, axes, and planes shown in the modeling window. They can be helpful when creating and defining your model.
    • Sketching
    • Geometry
      • Reference Geometry
        Create and modify reference planes, axes, or points.
      • Extrude
        Extrude profiles or 2D surfaces in one or two directions to create solids or 3D surfaces with optional end caps. Create a new part or combine, merge, subtract, or intersect the extruded shape with existing parts.
      • Revolve
        Revolve one or more faces, sketches, lines, or 2D edges about an axis.
      • Extract
        Extract selected geometry features and transfer them to a new part.
      • Sweep
        Sweep a profile along a path to create a solid or surface. Create a new part or combine, subtract, or intersect the swept shape with existing parts.
      • Multi Sweep
        Sweep multiple profiles along a path to create a solid or surface. Create a new part or combine, subtract, or intersect the swept shape with existing parts.
      • Pipe
        Create a pipe along one or more edges/lines. The pipe has a uniform cross section that can be circular, square, rectangular, or triangular.
      • Loft
        Create a solid loft or a lofted surface from profiles and guide curves. Create a new part from the loft or combine, subtract, or intersect the loft with existing parts.
      • Pattern
        Create a linear or circular pattern of parts or faces.
      • Mirror
        Mirror parts across a symmetry plane.
      • NURBS Curve
        Create a NURBS curve, which is a free-form curve.
      • Blend Curve
        Create a free-form curve that blends into one or more existing curves, surfaces, or edges.
      • Offset Curve
        Create a copy of one or more curves at a specified distance from the source curves. This tool can be used on both 2D and 3D curves.
      • Helix Curve
        Create a helix (or a spiral if the top and bottom radii are different).
      • Extend Curve
        Extend a curve and edit the extension.
      • Face Curve
        Extract isoparametric curves from a surface in the U or V direction. This is useful for creating trim curves that run along a surface but are not attached to it.
      • Divide Curve
      • Boolean
        Create a new part by using one set of solids to edit another set of solids.
      • Fillets
        Create fillets or chamfers along an edge.
      • Project & Split
        Project tools onto targets in a specified direction and split the targets. You can also extract the projection without splitting the targets to create wire geometry.
      • Slice
        Slice a set of solid objects with a cutting plane or surfaces.
      • Intersect
        Retain only the intersecting portions of one or more parts.
      • Shell
        Remove material and create thin walls to generate a shelled part.
      • Draft
        Add draft to one or more faces of a part.
      • Push/Pull
        Push, pull, or revolve a face, sketch, line, or 2D edge to extrude it into a solid or surface, create or resize a hole, eliminate rounds, or modify wall thickness.
      • Extend Face
      • Offset
        Offset surfaces or parts, thicken surface parts and convert them to solids, or thicken and hollow solid parts.
      • Move Faces
        Translate, rotate, copy, or extend features.
      • Partition
        Divide a solid part into design and non-design regions by selecting a hole, pocket, or face to offset.
      • Simplify
        Clean up problem areas in the geometry of a model before running an analysis.
      • Patch
        Use the Patch tool to fill in missing surfaces, or to remove and remake bad or problematic surfaces.
      • Scale
        Resize parts in your model, which is useful when working with an imported model that is associated with a different default unit system.
      • Replace Geometry
        Replace a part in your model with an alternative design.
    Perform Feasibility, Blank Fit, and Blank Nesting analyses.
  • Die Face Design
    Open any part in Studio to design the die, and import the die face design into Inspire Form from Studio.
    Perform tryout analyses to validate die designs.
    Analyze the trim angle of the free edges of the part with reference to the draw direction.
    Review forming outcomes through the Analysis Explorer.
  • Reference
    View the glossary or frequently asked questions.
    Learn keyboard shortcuts and mouse controls for common operations.
2022.3
  1. Home
  3. Geometry
  4. Extend Face
  • What's New
  • Get Started
  • Tutorials
  • Die Face Design
  • Reference
Index
Extend Face
