CONDUCTIVITY_MODEL
Specifies a thermal conductivity model for the temperature equation.
AcuSolve Command
CONDUCTIVITY_MODEL("name") {parameters...}
Qualifier
User-given name.
type (enumerated) [=none]
Type of the thermal conductivity.
constant or const
Constant isotropic conductivity. Requires conductivity.
constant_prandtl_number or const_pr
Constant Prandtl number isotropic conductivity. Requires prandtl_number.
ramped or ramp
Ramp the isotropic conductivity to a constant value. Requires conductivity.
piecewise_linear or linear
Piecewise linear curve fit. Requires curve_fit_values and curve_fit_variable.
cubic_spline or spline
Cubic spline curve fit isotropic conductivity. Requires curve_fit_values and curve_fit_variable.
user_function or user
User-defined function. Requires user_function, user_values and user_strings.
constant_anisotropic or const_aniso
Constant anisotropic conductivity. Requires anisotropic_conductivity.
piecewise_linear_anisotropic
Piecewise linear curve fit anisotropic conductivity. Requires anisotropic_curve_fit_values and anisotropic_curve_fit_variable.
cubic_spline_anisotropic
Cubic spline curve fit anisotropic conductivity. Requires anisotropic_curve_fit_values and anisotropic_curve_fit_variable.
user_function_anisotropic
User-defined function anisotropic conductivity. Requires anisotropic_user_function, anisotropic_user_values and anisotropic_user_strings.
cylindrical_anisotropic
Anisotropic conductivity in a cylindrical system. Requires cylindrical_center, cylindrical_axis, anisotropic_conductivity.
sutherland
Sutherland temperature dependent conductivity. Requires sutherland_reference_conductivity, sutherland_reference_temperature, sutherland_constant.
gas_kinetic
Gas kinetic conductivity model for gases only. Requires GAS_KINETIC_MODEL.
conductivity or cond (real) >=0 [=0]
Constant value of the isotropic thermal conductivity. Used with constant and ramped types.
prandtl_number or pr (real) >=0 [=0.71]
Prandtl number value. Used with constant_prandtl_number type.
curve_fit_values or curve_values (array) [={0,0}]
A two-column array of independent-variable/isotropic conductivity data values. Used with piecewise_linear and cubic_spline types.
curve_fit_variable or curve_var (enumerated) [=temperature]
Independent variable of the curve fit for isotropic conductivity. Used with piecewise_linear and cubic_spline types.
x_coordinate or xcrd
X-component of coordinates.
y_coordinate or ycrd
Y-component of coordinates.
z_coordinate or zcrd
Z-component of coordinates.
x_reference_coordinate or xrefcrd
X-component of reference coordinates.
y_reference_coordinate or yrefcrd
Y-component of reference coordinates.
z_reference_coordinate or zrefcrd
Z-component of reference coordinates.
temperature or temp
Temperature.
species_1 or spec1
Species 1.
species_2 or spec2
Species 2.
species_3 or spec3
Species 3.
species_4 or spec4
Species 4.
species_5 or spec5
Species 5.
species_6 or spec6
Species 6.
species_7 or spec7
Species 7.
species_8 or spec8
Species 8.
species_9 or spec9
Species 9.
sutherland_reference_conductivity (real) >= 0 [=0.0241]
Sutherland model reference conductivity at sutherland_reference_temperature. Used with sutherland type.
sutherland_reference_temperature (real) > 0 [=273]
Sutherland model reference temperature corresponding to sutherland_reference_conductivity. Used with sutherland type.
sutherland_constant (real) > 0 [=194]
Sutherland model constant. Used with sutherland type.
user_function or user (string) [no default]
Name of the user-defined function. Used with user_function type.
user_values (array) [={}]
Array of values to be passed to the user-defined function. Used with user_function type.
user_strings (list) [={}]
Array of strings to be passed to the user-defined function. Used with user_function type.
anisotropic_conductivity or aniso_cond (array) [={0,0,0,0,0,0}]
A six-element array of the form {k11, k22, k33, k12, k23, k31} for the anisotropic conductivity. Used with constant_anisotropic type.
anisotropic_curve_fit_values or aniso_curve_values (array) [={0,0,0,0,0,0,0}]
A seven-column array of independent-variable/anisotropic conductivity data values, in the order variable, k11, k22, k33, k12, k23, k31. Used with piecewise_linear_anisotropic and cubic_spline_anisotropic types.
anisotropic_curve_fit_variable or aniso_curve_var (enumerated) [=temperature]
Independent variable of the curve fit for anisotropic conductivity. Used with piecewise_linear_anisotropic and cubic_spline_anisotropic types.
temperature or temp
Temperature.
species_1 or spec1
Species 1.
species_2 or spec2
Species 2.
species_3 or spec3
Species 3.
species_4 or spec4
Species 4.
species_5 or spec5
Species 5.
species_6 or spec6
Species 6.
species_7 or spec7
Species 7.
species_8 or spec8
Species 8.
species_9 or spec9
Species 9.
anisotropic_user_function or aniso_user (string) [no default]
Name of the user-defined function for anisotropic conductivity. Used with user_function_anisotropic type.
anisotropic_user_values (array) [={}]
Array of values to be passed to the user-defined function for anisotropic conductivity. Used with user_function_anisotropic type.
anisotropic_user_strings (list) [={}]
Array of strings to be passed to the user-defined function for anisotropic conductivity. Used with user_function_anisotropic type.
cylindrical_center (array) [={0,0,0}]
Array of the origin of a local cylindrical coordinate system. Used with cylindrical_anisotropic type and cylindrical_axis.
cylindrical_axis (array) [={0,0,1}]
Array of the longitudinal axis of a local cylindrical coordinate system. Used with cylindrical_anisotropic type and cylindrical_center.
multiplier_function (string) [=none]
User-given name of the multiplier function for scaling the conductivity. If none, no scaling is performed.
turbulent_prandtl_number_type (enumerated) [=constant]
Used with turbulence models.
constant
User-specified turbulent Prandtl number. Requires turbulent_prandtl_number.
auto
Turbulent Prandtl number is computed based on local flow and material properties.
turbulent_prandtl_number or turb_pr (real) >0 [=0.91]
Value of the turbulent Prandtl number. Used when turbulent_prandtl_number_type = constant.
This command specifies a thermal conductivity model for the temperature (energy) equation. This model is applicable to fluid, solid, and shell element sets.
CONDUCTIVITY_MODEL commands are referenced by MATERIAL_MODEL commands, which in turn are referenced by ELEMENT_SET commands:
CONDUCTIVITY_MODEL( "my conductivity model" ) {
   type                                = constant
   conductivity                        = 2.521e-2
 MATERIAL_MODEL( "my material model" ) {
   conductivity_model                  = "my conductivity model"
 ELEMENT_SET( "fluid elements" ) {
   material_model                      = "my material model"
The heat flux vector q is given by either:(1)
q = κ ∇ T
where κ is an isotropic thermal conductivity, or by:(2)
q = K · ∇ T
where K is an anisotropic thermal conductivity.
A constant conductivity model defines a spatially constant isotropic thermal conductivity, as in the above example. A constant_anisotropic conductivity model is also spatially constant but varies in each direction. It requires that the six elements of the conductivity tensor be specified:
CONDUCTIVITY_MODEL( "my anisotropic conductivity model" ) {
    type                      = constant_anisotropic
    anisotropic_conductivity  = { 0.02, 0.03, 0.04, 0, 0, 0 }
The elements of the anisotropic conductivity tensor are always specified in the order k11, k22, k33, k12, k23, k31.
For cylindrical objects, for example, the battery packs, it is preferable to specify anisotropic conductivity in the local cylindrical system. When a cylinder is at an angle of 45 degrees (0.785 rad) to the x and z axis and the cylinder center is located at the origin of the coordinate, the elements of the anisotropic conductivity tensor are specified in the order krr, ktt, kzz, krt, ktz, krz, krr is for the radial conductivity 1.0 W/(m K); ktt is the azimuthal conductivity 50 W/(m K); kzz is the axial conductivity 50 W/(m K).
CONDUCTIVITY_MODEL( "MyCylindricalConductivity" ) {
    type                       = cylindrical_anisotropic
    cylindrical_center         = { 0.0,   0.0,   0.0; }
    cylindrical_axis           = { 0.785,   0.0,   0.785; }
    anisotropic_conductivity   = { 1.0, 50.0, 50.0, 0.0, 0.0, 0.0; }
A constant_prandtl_number conductivity model computes the isotropic thermal conductivity from the specific heat at constant pressure and the viscosity:(3)
where Cp is the specific heat at constant pressure, specified by the SPECIFIC_HEAT_MODEL command; μ is the viscosity, specified by the VISCOSITY_MODEL command; and Pr is the Prandtl number, given by constant_prandtl_number. For example,
SPECIFIC_HEAT_MODEL( "air" ) {
    type                     = constant
    specific_heat            = 1005
VISCOSITY_MODEL( "air" ) {
    type                     = constant
    viscosity                = 1.781e-5
CONDUCTIVITY_MODEL( "air" ) {
    type = constant_prandtl_number
    prandtl_number           = 0.71
MATERIAL_MODEL( "air" ) {
    specific_heat_model      = "air"
    viscosity_model          = "air"
    conductivity_model       = "air"
yields a thermal conductivity of 2.521e-2.
A ramped conductivity model is the same as the constant one, except that the isotropic conductivity is ramped down from 1000 times the conductivity value at time step 1 to the conductivity value at time step 10. For example,
CONDUCTIVITY_MODEL( "ramped conductivity model" ) {
    type           = ramped
starts at conductivity of 2.521e+1 at time step one and reduces the conductivity until time step 10, at which time a conductivity of 2.521e-2 is used.
Conductivity models of types piecewise_linear and cubic_spline may be used to define the isotropic conductivity as a function of a single independent variable. For example,
CONDUCTIVITY_MODEL( "curve fit conductivity model" ) {
    type               = piecewise_linear
    curve_fit_values   = { 273, 2.42e-2 ;
                           323, 2.76e-2 ;
                           373, 3.10e-2 ;
                           423, 3.44e-2 ; }
curve_fit_variable     = temperature
defines the conductivity as a function of temperature. The curve_fit_values parameter is a two-column array corresponding to the independent variable and the conductivity values. The independent variable values must be in ascending order. The limit point values of the curve fit are used when curve_fit_variable falls outside of the curve fit limits.
The curve_fit_values data may be read from a file. For the above example, the curve fit values may be placed in a file, such as conductivity.fit:
273         2.42e-2
323         2.76e-2
373         3.10e-2
423         3.44e-2
and read by:
    curve_fit_values    = Read( "conductivity.fit" )
Conductivity models of types piecewise_linear_anisotropic and cubic_spline_anisotropic may be used to define the anisotropic conductivity as a function of a single independent variable. For example,
CONDUCTIVITY_MODEL( "curve fit anisotropic conductivity model" ) {
    type                             = piecewise_linear_anisotropic
    anisotropic_curve_fit_values     = { 273, 2.42e-2, 3.42e-2, 4.42e-2, 0, 0, 0 ;
                                         323, 2.76e-2, 3.76e-2, 4.76e-2, 0, 0, 0 ;
                                         373, 3.10e-2, 4.10e-2, 5.10e-2, 0, 0, 0 ;
                                         423, 3.44e-2, 4.44e-2, 5.44e-2, 0, 0, 0 ; }
    anisotropic_curve_fit_variable   = temperature
defines the anisotropic conductivity as a function of temperature. The anisotropic_curve_fit_values parameter is a seven-column array corresponding to the independent variable and the component values of the conductivity tensor. The independent variable values must be in ascending order. The limit point values of the curve fit are used when anisotropic_curve_fit_variable falls outside of the curve fit limits.
The anisotropic_curve_fit_values data may be read from a file. For the above example, the curve fit values may be placed in a file, such as anisotropic_conductivity.fit:
273    2.42e-2    3.42e-2   4.42e-2    0    0    0
323    2.76e-2    3.76e-2   4.76e-2    0    0    0
373    3.10e-2    4.10e-2   5.10e-2    0    0    0
423    3.44e-2    4.44e-2   5.44e-2    0    0    0
and read by:
    anisotropic_curve_fit_values     = Read( "anisotropic_conductivity.fit" )
The sutherland type defines a temperature dependent conductivity model according to the following equation:(4)
k= k 0 ( T T 0 ) 3/2 T 0 +S T+S MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4Aaiabg2 da9iaadUgadaWgaaWcbaGaaGimaaqabaGcdaqadaqaamaalaaabaGa amivaaqaaiaadsfadaWgaaWcbaGaaGimaaqabaaaaaGccaGLOaGaay zkaaWaaWbaaSqabeaadaWcgaqaaiaaiodaaeaacaaIYaaaaaaakmaa laaabaGaamivamaaBaaaleaacaaIWaaabeaakiabgUcaRiaadofaae aacaWGubGaey4kaSIaam4uaaaaaaa@45F3@
where k 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4AamaaBa aaleaacaaIWaaabeaaaaa@37CC@ is the sutherland_reference_conductivity at the specified sutherland_reference_temperature ( T 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamivamaaBa aaleaacaaIWaaabeaaaaa@37B5@ ), T MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamivaaaa@36CF@ is the model temperature and S MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uaaaa@36CE@ is the sutherland_constant.
For example,
VISCOSITY_MODEL( "Sutherland Model" ) {
type = sutherland
sutherland_reference_conductivity = 2.41e-2
sutherland_reference_temperature = 273.0
sutherland_constant = 194
Conductivity types user_function and user_function_anisotropic may be used to model more complex behaviors; see the AcuSolve User-Defined Functions Manual for a detailed description of user defined functions.
For example, consider an isotropic conductivity model which is a linear function of temperature and species 1. Then the input command may be given by:
CONDUCTIVITY_MODEL( "UDF conductivity model" ) {
    type          = user_function
    user_function = "usrConductivityExample"
    user_values   = { 0.02,   # constant value
                      1.e-3,  # temperature scale
                      1.e-3 } # species scale
where the user-defined function "usrConductivityExample" may be implemented as follows:
#include "acusim.h"
#include "udf.h"
UDF_PROTOTYPE( usrConductivityExample ) ;                      /* function prototype                */
Void usrConductivityExample (
    UdfHd    udfHd,                                            /* Opaque handle for accessing data  */
	Real*    outVec,                                           /* Output vector                     */
	Integer  nItems,                                           /* Number of elements                */
	Integer  vecDim                                            /* = 1                               */
    Integer  elem ;                                            /* an element counter                 */
    Real     cond0 ;                                           /* reference conductivity             */
    Real     sScale ;                                          /* species scale                      */
    Real     tScale ;                                          /* temperature scale                  */
    Real*    spec ;                                            /* species field                      */
    Real*    temp ;                                            /* temperature field                  */
    Real*    usrVals ;                                         /* user values                        */
udfCheckNumUsrVals( udfHd, 3 ) ;                               /* check for error                    */
    usrVals  = udfGetUsrVals( udfHd ) ;                        /* get the user vals                  */
    cond0    = usrVals[0] ;                                    /* reference cond.                    */
    tScale   = usrVals[1] ;                                    /* temp. scale                        */
    sScale   = usrVals[2] ;                                    /* spec. scale                        */
    temp     = udfGetElmData( udfHd, UDF_ELM_TEMPERATURE ) ;   /* get temperature                    */
    spec     = udfGetElmData( udfHd, UDF_ELM_SPECIES ) ;       /* get species                        */
    for ( elem = 0 ; elem < nItems ; elem++ ) {
        outVec[elem] = cond0
                     + tScale * temp[elem]
                     + sScale * spec[elem] ;
} /* end of usrConductivityExample()        */
The dimension of the returned conductivity vector, outVec, is the number of elements. The same conductivity model but in anisotropic form can be defined by:
CONDUCTIVITY_MODEL( "UDF anisotropic conductivity model" ) {
   type                        = user_function_anisotropic
   anisotropic_user_function   = "usrAnisoConductivityExample"
   anisotropic_user_values     = { 0.02,   # constant value
where the user-defined function "usrAnisoConductivityExample" may be implemented as follows:
#include "acusim.h"
#include "udf.h"
UDF_PROTOTYPE( usrAnisoConductivityExample ) ;                                   /* function prototype               */
Void usrAnisoConductivityExample (
	Integer                     vecDim                                           /* = 6                              */
    Real                        cond ;                                           /* conductivity                     */
    Real*                       tScale ;                                         /* temperature scale                */
    usrVals                     udfGetUsrVals( udfHd ) ;                         /* get the user vals                */
       cond = cond0 + tScale * temp[elem] + sScale * spec[elem] ;
       outVec[0*nItems+elem]    = cond ;
       outVec[1*nItems+elem]    = cond ;
       outVec[2*nItems+elem]    = cond ;
       outVec[3*nItems+elem]    = 0 ;
       outVec[4*nItems+elem]    = 0 ;
       outVec[5*nItems+elem]    = 0 ;
}        /* end of usrAnisoConductivityExample() */
The dimension of the returned conductivity vector, outVec, is the number of elements times six.
The multiplier_function parameter may be used to uniformly scale both isotropic and anisotropic conductivity values. The value of this parameter refers to the user-given name of a MULTIPLIER_FUNCTION command in the input file. For example, a ramped isotropic conductivity may be specified by:
CONDUCTIVITY_MODEL( "similar to ramped conductivity model" ) {
   type                     = constant
   multiplier_function      = "ramped"
   MULTIPLIER_FUNCTION( "ramped" ) {
   type                     = piecewise_log_linear
   curve_fit_values         = { 1, 1000 ; 10, 1 }
   curve_fit_variable       = time_step
In areas of turbulent flow the molecular conductivity κ or K is replaced by the total conductivity κ + κt or K+ κtI(where I is the identity matrix) in the definition of the heat flux vector for the isotropic or anisotropic cases respectively. The turbulent conductivity κt is defined by(5)
where μ t is the turbulent viscosity, given by the turbulence model in use; and Prt is the turbulent Prandtl number, given by turbulent_prandtl_number.
