Laminar Couette Flow with Imposed Pressure Gradient
In this application, AcuSolve is used to simulate the viscous flow of water between a moving and a stationary plate with an imposed pressure gradient. AcuSolve results are compared with analytical results described in White (1991). The close agreement of AcuSolve results with analytical results validates the ability of AcuSolve to model cases with imposed pressure gradients.
Problem Description
AcuSolve Results
Summary
Simulation Settings for Laminar Couette Flow with Imposed Pressure Gradient
SimLab database file: <your working directory>\couette_flow\couette_flow.slb
Global
- Problem Description
- Solution Type - Steady State
- Flow - Laminar
- Auto Solution Strategy
- Relaxation factor - 0.2
- Material Model
- Air
- Density - 1.0 kg/m3
- Viscosity - 1.0 kg/m-sec
- Air
- Body Force
- DP/DL
- Gravity
- Z-component - 18.0 m/sec2
- Gravity
Model
- DP/DL
- Volumes
- Fluid
- Element set
- Material model - Air
- Body force - DP/DL
- Element set
- Fluid
- Surfaces
- Max_X
- Simple Boundary Condition
- Type - Symmetry
- Max_Y
- Type - Wall
- Wall velocity type - Cartesian
- Z-velocity - 3.0 m/s
- Max_Z
- Simple Boundary Condition - (disabled to allow for periodic conditions to be set)
- Min_X
- Type - Symmetry
- Min_Y
- Type - Wall
- Min_Z
- Max_X
- Periodics
- Periodic 1
- Periodic Boundary Conditions
- Type - Periodic
- Periodic 1
References
F. M. White. “Viscous Fluid Flow”. Section 3-2.3. McGraw-Hill Book Co., Inc. New York. 1991.
