THERMAL_SHELL
Creates shell elements from surface elements for temperature field only.
AcuSolve Command
THERMAL_SHELL ("name") {parameters}
Qualifier
User-given name.
- shape (enumerated) [no default]
- Shape of the surfaces in this set.
- three_node_triangle or tri3
- Three-node triangle.
- four_node_quad or quad4
- Four-node quadrilateral.
- six_node_triangle or tri6
- Six-node triangle.
- element_set or elem_set (string) [no default]
- User-given name of the parent element set.
- surfaces (array) [no default]
- List of element surfaces.
- surface_sets (list) [={}]
- List of surface set names (strings) used in the THERMAL_SHELL command. When using this option, the connectivity, shape and parent element of the surfaces are provided by the surface set container. It is unnecessary to specify the shape, element_set and surfaces parameters directly to the THERMAL_SHELL command. This option is used in place of directly specifying these parameters. In the event that both of the surface_sets and surfaces parameters are provided, the full collection of surface elements will be read, and a warning message will be issued. The surface_sets option is a preferred method to specify the surface elements. This option provides a support for mixed element topologies and simplifies pre-processing and post-processing.
- num_shell_layers or layers (integer) >0 [=1]
- Number of layers in the shell.
- material_models (list) [={}]
- List of material model names (strings) for the shell layers. Number of entries in the list must equal num_shell_layers.
- shell_thickness_type (enumerated) [=constant]
- Type of shell thickness.
- constant or const
- Constant shell thickness.
- shell_thicknesses or thick (array) [={}]
- Thicknesses of the shell layers. Number of entries in the array must equal num_shell_layers. Used with constant shell thickness type and for shell medium only.
- body_force (string) (string)
- User-given name of the volumetric body force to be applied to this element
set. If none, no body force is applied. Note: Only heat source will be considered.
THERMAL_SHELL( "pipes" ) {
surface_sets = {“pipe wall”}
num_shell_layers = 2
material_models = {"Aluminum",”Iron”}
shell_thicknesses = {0.001,0.002}
body_force = none
