udfGetEbcData()
Return data at the surface quadrature point.
data = udfGetEbcData( udfHd, dataName ) ;
AcuSolve User-Defined Example Boundary Condition
- udfHd
- The opaque handle (pointer) which was passed to the user function.
- dataName (integer)
- Symbolic name of the requested data.
- UDF_EBC_VELOCITY
- Velocity.
- UDF_EBC_ACCELERATION
- Acceleration.
- UDF_EBC_PRESSURE
- Pressure.
- UDF_EBC_TEMPERATURE
- Temperature.
- UDF_EBC_SPECIES
- Species.
- UDF_EBC_EDDY_VISCOSITY
- Turbulence eddy viscosity.
- UDF_EBC_KINETIC_ENERGY
- Turbulence kinetic energy.
- UDF_EBC_EDDY_FREQUENCY
- Turbulence eddy frequency.
- UDF_EBC_GRAD_VELOCITY
- Gradient of velocity.
- UDF_EBC_GRAD_PRESSURE
- Gradient of pressure.
- UDF_EBC_GRAD_TEMPERATURE
- Gradient of temperature.
- UDF_EBC_GRAD_SPECIES
- Gradient of species.
- UDF_EBC_MESH_DISPLACEMENT
- Mesh displacement.
- UDF_EBC_MESH_VELOCITY
- Mesh velocity.
Return Value
- data (Real*)
- Pointer to one, two, or three dimensional real array of the requested data. The dimensions of
the array depend on dataName as follows. If the third (slowest)
dimension of the array is equal to one, then the array may be treated as two
dimensional. If the second dimension is likewise one, then the array is one dimensional.
The x, y, z components of the gradient for gradient quantities are always contained in
the last nontrivial dimension.
dataName First Dimension Second Dimension Third Dimension UDF_EBC_VELOCITY nItems 3 1 UDF_EBC_ACCLERATION nItems 3 1 UDF_EBC_PRESSURE nItems 1 1 UDF_EBC_TEMPERATURE nItems 1 1 UDF_EBC_SPECIES nItems udfGetNumSpecs() 1 UDF_EBC_EDDY_VISCOSITY nItems 1 1 UDF_EBC_KINETIC_ENERGY nItems 1 1 UDF_EBC_EDDY_FREQUENCY nItems 1 1 UDF_EBC_GRAD_VELOCITY nItems 3 3 UDF_EBC_GRAD_PRESSURE nItems 3 1 UDF_EBC_GRAD_TEMPERATURE nItems 3 1 UDF_EBC_GRAD_SPECIES nItems udfGetNumSpecs() 3 UDF_EBC_MESH_DISPLACEMENT nItems 3 1 UDF_EBC_MESH_VELOCITY nItems 3 1
Real* data ;
Real u, v, w ;
Real u_x, v_x, w_x, u_y, v_y, w_y, u_z, v_z, w_z ;
Real spec_x, spec_y, spec_z ;
Integer surf, nSpecs, specId ;
data = udfGetEbcData( udfHd, UDF_EBC_VELOCITY ) ;
for ( surf = 0 ; surf < nItems ; surf++ ) {
u = data[0*nItems+surf] ;
v = data[1*nItems+surf] ;
w = data[2*nItems+surf] ;
data = udfGetEbcData( udfHd, UDF_EBC_GRAD_VELOCITY ) ;
u_x = data[0*nItems+surf] ;
v_x = data[1*nItems+surf] ;
w_x = data[2*nItems+surf] ;
u_y = data[3*nItems+surf] ;
v_y = data[4*nItems+surf] ;
w_y = data[5*nItems+surf] ;
u_z = data[6*nItems+surf] ;
v_z = data[7*nItems+surf] ;
w_z = data[8*nItems+surf] ;
data = udfGetEbcData( udfHd, UDF_EBC_GRAD_SPECIES ) ;
nSpecs = udfGetNumSpecs( udfHd ) ;
for ( specId = 0 ; specId < nSpecs ; specId++ ) {
/* 3 components of gradient of species */
spec_x = data[nItems*(0*nSpecs+specId)+surf] ;
spec_y = data[nItems*(1*nSpecs+specId)+surf] ;
spec_z = data[nItems*(2*nSpecs+specId)+surf] ;
}Errors
- This routine expects a valid udfHd.
- This routine may only be called within an Element Boundary Condition user function.
- dataName must be one of the values given above.
- The problem must contain the equation associated with the requested data.
