udfSetSdElmId()
Set the ID of an interior element set.
udfSetSdElmId( udfHd, elmId ) ;
AcuSolve User-Defined Subdomain Routine
- udfHd
- The opaque handle (pointer) which was passed to the user function.
- elmId (integer)
- Element set index.
Return Value
None.
Integer nElms, elmId ;
nElms = udfGetNSdElms( udfHd ) ;
for ( elmId = 0 ; elmId < nElms ; elmId++ ) {
}Errors
- This routine expects a valid udfHd.
- This routine may only be called within an external code.
- elmId must be from 0 to nElms - 1.
