Engineering Solutions
Unified environment for vertical engineering disciplines for simulation, analysis, and design optimization.
Crash
The Crash application in Engineering Solutions offers a tailored environment in Altair HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with a runnable solver deck in both solvers Altair Radioss and LS-DYNA. A one-way transfer to Altair HyperCrash to complete safety setup within Altair HyperWorks is also available.
For more information, reference the Engineering Solutions help manual.
CFD
Engineering Solutions offers a wide range of tools enabling the user to perform CFD modeling in an efficient manner.
  • Import interfaces for all major CAD tools (CATIA, Creo, NX,…)
  • Powerful geometry - FE based cleanup/generation capabilities
  • Several surface meshing algorithms for curvature dependent surface meshing with local refinement and user-defined growth rate
  • Robust volume mesh generation, such as BL mesh, tetramesh, hybrid grids or hex-core meshing
  • Native export/import interfaces for all major CFD tools
  • Several surface meshing algorithms, such as BL mesh, tetramesh, curvature dependent surface meshing with local refinement and user-defined growth rate
  • Robust volume mesh generation, such as hybrid grids or hex-core meshing
  • Case setup and solver launch for CFD solver Altair AcuSolve
  • CFD post-processing in Altair HyperView
  • Smooth integration of Altair HyperStudy and AcuSolve to perform optimization studies
Noise and Vibration
The NVH user profile is a Altair HyperWorks environment customized for automotive full vehicle NVH modeling and analysis needs. It includes a number of integrated components to help NVH users execute a typical full vehicle analysis process.
Benefits
  • Simulation of real-world events
    • Directly simulate customer usage experience
    • Drive physical prototype development
    • Identify problems related to specific loadcase/response
    • Understand cost and benefit
  • Physical root cause understanding
    • Identify source-path-receiver clearly
    • Most effective solutions often come from source reduction
    • Understand noise/vibration energy transfer paths
    • Identify most sensitive parts and cost effective solutions
    • Validate CAE model through trend prediction
    • Obtain force distribution for component level analysis and optimization
  • Ability to apply the entire NVH toolset
    • Effective problem resolution requires using the right tools
    • Low frequency – modal alignment and contribution analysis
    • Mid frequency – transfer path, point mobility, and panel analysis
    • Effective isolation
    • Mass damper and tuned mass dampers
    • Mastic or beads on panels
    • Optimization
For more information, reference the Engineering Solutions help manual or the HyperWorks NVH help manual.
Aerospace
This profile is aimed to help to capture the aerospace model building process and tools needed for automation.
Durability Director
Durability Director is a solver-neutral, process-oriented customization of Altair HyperWorks that addresses many of the challenges associated with assessing the fatigue life of mechanical components. Durability Director manages the entire durability process from cascading measured loads, to predicting fatigue on individual components in the system.
Suspension Director
Suspension Director (SD) is an industry specific solution that is integrated with MotionView and utilizes many aspects of Altair HyperWorks to assist with the engineering of vehicle suspensions. SD contains several industry standard suspension topologies and analyses and is easily customizable. It utilizes state of the art assembly technology in Altair MotionView and allows you to store and retrieve models using Library Manager. When using SD, all aspects of general MotionView are available to the user.
SD enables you to quickly add, solve and post-process a suspension model that is in the library. Or you can customize the library by adding additional suspensions, analyses or auto-entities to fit your engineering needs.
