Lid-Driven Cavity in 2D
Problem Description
A square cavity with a side length of L°= 1e-3° m is filled with water (density: 1000 kg/m3, dynamic viscosity: 1e-3 kg/m/s). The upper wall is moved with a constant velocity U0 imposing a rotational movement of the fluid in the cavity. Here, the configurations with Re°=°100, Re°=°1000 and Re°=°10000 are simulated by adjusting the velocity of the lid correspondingly. The highly-resolved Finite-Difference calculations by Ghia et al with a grid resolution of 257x257 are taken as reference.
Numerical Setup
Results
S. Adami, H. Hu and N. Adams, "A generalized wall boundary condition for smoothed particle hydrodynamics," Journal of Computational Physics, vol. 231, pp. 7057-7075, 2012.
U. Ghia and K. S. C. Ghia, "High-Re solutions for incompressible flow using the Naview-Stokes equations and a multigrid method," Journal of Computational Physics, vol. 48, pp. 387-411, 1982.
