NFX-T: 1000 Simple Single Phase Gearbox
Set up a simple single phase gearbox for drive train oiling simulation using SimLab for CFD-nanoFluidX solution. Oil distribution will be analyzed and basics of the post-processing in SimLab will be demonstrated.
- Select Unit System
- Import CAD Geometry
- Define SPH Flow Solution
- Define Oil properties
- Define Initial Conditions
- Define Body Force
- Assign Motion
- Create SPH Particles
- Set Solver Settings
- Set Result Request
- Check Simulation Data
- Perform Basic Post-processing in SimLab
![](../../images/nfx_t_1000_operating_condition.jpg)
Prerequisites
To run this simulation, you will need access to a licensed version of SimLab and nanoFluidX.
Model Files
Tutorial Video
Additional Resources
For more tutorials, visit the SimLab Learning Center.
