Platform Support
Platforms, operating systems, and processors supported by Altair Simulation 2022.3 products, which includes 2022.3 solver packages.
| Platforms | Altair Simulation 2022.3 | |||
| OS | Version | Architecture | GUI Products | Solvers |
| Windows | 10 | x86_64 | YES | YES |
| Windows | 11 | x86_64 | YES | YES |
| Linux | RHEL / Oracle Linux 8.4 SLES 15 SP3 |
- Windows Ultra High Definition (UHD/HiDPI) support requires Windows 10 Update 1709 or higher
- RHEL= Red Hat Enterprise Linux
- SLES = SUSE Linux Enterprise Server
- Linux
- Altair Simulation products may install and run on other non-supported Linux distributions not mentioned or referred to in this documentation, but Altair does not test, certify, verify or warrant the reliability of the products on these platforms.
- Ultra High Definition (UHD)
- UHD resolution support (2160p) is only available for Windows 10
(1709 or higher).
- Using Windows 200% scaling for 2160p is recommended.
- Our recommended HD setting is 1080p for FHD and our Ultra HD setting is 2160p.
- Java based tools within our products may still show some scaling issues under Ultra HD resolution.
(1709 or higher).
Refer to the Hardware Recommendations and Certifications section for details.
Altair Simulation Products
- Altair® HyperWorks Desktop™ Applications
- Altair® SimLab®
- Altair SimSolid® (Windows only)
- Altair® Feko®
- Altair® Feko® Applications
- Altair® newFASANT™
- Altair® WinProp™
- Altair® Flux®
- Altair® Solvers™
- Altair® OptiStruct®
- Altair® Radioss®
- Altair® MotionSolve®
- Altair® HyperXtrude®
- Altair® Manufacturing Solver™
- Altair® Multiscale Designer®
- Altair® Seam®
- Altair® CFD Solvers™
- Altair® AcuSolve®
- Altair® ultraFluidX® (Linux only)
- Altair® nanoFluidX® (Linux only)
- Altair® Virtual Wind Tunnel for ultraFluidX™
- Altair® Activate®
- Altair® Compose®
- Altair® EDEM™
- Altair® Inspire™ (Windows only)
- Altair® Inspire Cast™ (Windows only)
- Altair® Inspire Extrude™ (Windows only)
- Altair® Inspire™ Extrude Metal
- Altair® Inspire™ Extrude Polymer
- Altair® Inspire™ Friction Stir Welding
- Altair® Inspire™ Resin Transfer Molding
- Altair® Inspire Form™ (Windows only)
- Altair® Inspire™ Mold (Windows only)
- Altair® Inspire™ PolyFoam (Windows only)
- Altair® Inspire Render™ (Windows only)
- Altair® Inspire Studio™ (Windows only)
Platforms Added in Altair Simulation 2022.3
- Windows 11 (64-bit).
- SUSE Linux Enterprise Server 15 SP3
- Red Hat Enterprise Linux 8.4/Oracle Linux 8.4
Platforms Dropped in Altair Simulation 2022.3
- SUSE Linux Enterprise Server 15 SP2
- Red Hat Enterprise Linux 8.3/CentOS 8.3
Minimum Operating System Requirements
| System/Hardware Information | Linux | Windows | ||
| Operating Systems |
RHEL 8.4 (64-bit) Oracle Linux 8.4 (64-bit) SLES 15 SP3 (64-bit) |
10
(64-bit) 11 (64-bit) |
| Memory | 16 GB (higher recommended) | 16 GB (higher recommended) | ||
| Complete Install Disk Space ~8 GB temporary disk space required for full Altair Simulation 2022.3 installation |
Applications 72 GB |
Help 12 GB |
Applications 110 GB |
Help 12 GB |
| Graphics Hardware 2 | OpenGL 3D graphics accelerator
compatible with OpenGL 3.3 or higher Vulkan 1.2 or higher OpenCL 2.1 required True color (24-bit) support Install/update to most recent OpenGL patches/drivers 1920x1080 screen resolution or higher for optimal user experience 4 GB or higher dedicated RAM Only AMD and NVIDIA GPUs supported (Intel chipsets are not supported) |
Linux System Requirements
Run the HyperWorks compatibility tool to validate your Linux compatibility with Altair Simulation products located under the <INSTALL_PATH>/altair/hwdesktop/utility/HWCompatibilityTool/ folder.
