| 1. | From the Menu Bar, select LoadCase > Gravity Load > Create. |
| 2. | Enter a name in the Gravity Load Creation field and validate with Ok. |
| 3. | Enter the function values to import from an already existing function. (Learn how to create the function.) |
| 4. | In the Selections folder, select nodes using the different tools from the Selection folder. |
Button |
Behavior |
pick nodes in the graphic window, and then press Enter, right-click the mouse button or select Yes or Cancel in the Dialog menu bar. |
add/remove object by ellipse selection. |
add nodes by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
remove nodes by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
add all nodes. |
pick parts in the graphic window, and then press Enter, right-click the mouse button or select Yes or Cancel in the Dialog menu bar. |
add parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
remove parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
add the parts selected in the tree. |
remove the parts selected in the tree. |
| 5. | Click the Reference Axis folder. |
| 6. | Define the reference axis using the different tools of the Reference Axis folder. |
| 7. | In the Sensor folder, define the sensor to activate and deactivate the gravity. (Learn how to create a sensor.) |
| 8. | In the Properties folder, set a scale factor for the abscissa of the defined curve in the Scale factor field. |
| 9. | Click Function to modify the function. |
| 11. | Click Save to save the created gravity load; or |
Click Cancel to cancel the gravity load creation.
| 12. | Click Close to close the menu. |
