| 1. | From the Menu Bar, select LoadCase > Gravity Load > Modify. |
| 2. | Select gravity loads using one of the following methods: |
Button |
Behavior |
select all the gravity loads |
pick the arrow of the gravity load in graphic window to select it. When finished, answer the question in the Dialog menu bar with Yes or Cancel. |
select gravity loads by box (use the SHIFT key to use a polygon box). |
pick parts in the graphic window to select all the gravity loads applied to those parts. When finished, answer the question in the Dialog menu bar with Yes or Cancel |
select parts by box (use the SHIFT key to use a polygon box) to select all gravity loads applied to those parts. |
Click the gravity load line in the listing window to select it. Several gravity loads from this list can be selected using the SHIFT, CTRL, or SHIFT+CTRL keys. |
| 3. | Select only one gravity load and click |
| • | Change the gravity load name. |
| • | Select or deselect nodes or parts (see Node selection). |
| • | Modify the skew frame (see Reference axis). |
| • | Modify the sensor (see Sensor). |
| • | Modify the properties (see Properties setting). |
| • | Modify the gravity load direction (see Direction setting). |
| 4. | Click |
| 5. | Answer the question in the pop-up dialog window with Yes or Cancel. |
| 6. | Click Save to save the modified gravity load; or |
Click Cancel to cancel the gravity load modification.
| 7. | Click Close to close the menu. |
