| 1. | From the Menu Bar, select Model > Material. |
| 2. | Below are the available options to sort the material list: |
| • | Click |
| • | Click |
| • | Click |
| • | Click |
| 3. | Under Choose Material Law, select a material. |
| 4. | Click |
| 5. | Click |
| 6. | Enter the different values in the fields for the material: |
| • | Set the value or the material name. |
| • | Click the toggle button to switch options ON or OFF. |
| • | Click the button for the function to set or modify a function. |
| • | Set the number for the function needed and click Ok. |
| 7. | Optional: for materials that include curves, click |
A Plot Window opens.
| 8. | Click |
| • | In the new sub-window, select the directory to save the material to (left area part). |
| • | Enter the name of the material to save. |
| • | Select OK to save the material or Cancel to cancel the save. |
| 9. | Click Save to save the material creation; or |
Click Cancel to cancel the material creation.
| 10. | Click Close to close the menu. |
