Browsers supply a great deal of view-related functionality by listing the parts of a model in a tabular and/or tree-based
format, and providing controls inside the table that allow you to alter the display of model parts.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
The Pedestrian Impact tool automates the vehicle marking, impactors positioning and the export of solver decks with minimal
input, therefore reducing the full process lead time.
Create solver seatbelt features using Control Points.
After the seatbelt mesh is realized, Control Points are defined in the browser. The Control Points context menu
allows you to select various seatbelt features and perform automatic creation.
If you are using the LS-DYNA solver:
In the Seatbelt Browser, right-click on either the
first or last control point under the appropriate seatbelt system to
display the context menu.
Select Retractor to create an
*ELEMENT_SEATBELT_RETRACTOR and its attachment to the structural
components via *CONSTRAINED_NODAL_RIGID_BODY or
*CONSTRAINED_EXTRA_NODES.
Select Retractor + Pre-Tensioner to create an
*ELEMENT_SEATBELT_RETRACTOR and an *ELEMENT_SEATBELT_PRETENSIONER and
its attachment to the structural components via
*CONSTRAINED_NODAL_RIGID_BODY or *CONSTRAINED_EXTRA_NODES.
Select Constrained Extra Node to create an
attachment between the seatbelt and a rigid structural component via a
Select Constrained Nodal Rigid Body to create an
attachment between the seatbelt and a deformable structural component
via a *CONSTRAINED_NODAL_RIGID_BODY.
Select a Control Point that is common to two seatbelt entities,
right-click and select Create > Slipring 1D or Slipring 2D.
Sliprings allow you to create an *ELEMENT_SEATBELT_SLIPRING and its
If you are using the Radioss solver:
Select Anchor PreTensioner to create a SPRING to
model the pre-tension effect.
Select Retractor + PreTensioner to create two
SPRINGS to model the retractor effect and the pre-tensioner
effect.
Select Retractor + PreTensioner + LL (LOAD
LIMITER) to create three SPRINGS to model the retractor
effect, the pre-tension effect, and the load limiter effect.
right-click and select Create > Pulley.
This option allows you to create a SPRGIN of type PULLEY.
