hwi GetActiveClientHandle
HyperWorks Tcl Modify
View new features for HyperWorks Desktop 2022.3.
Automate common workflows using the Process Manager.
Ends automatic handle tracking and releases any handles acquired during handle tracking.
Gets a handle to the current session.
Gets a list of all active handles.
Begins automatic handle tracking.
