hwIObject GetClassName
Returns the class name as a string.
object_handle GetClassName
HyperWorks Tcl Query
Returns the class name.
None.
View new features for HyperWorks Desktop 2022.3.
Automate common workflows using the Process Manager.
Returns the super class name as a string.
Tests if the given class name is the class or a descendant of the named class.
Used to free this interface object.
Casts the supplied object to an hwIObject.
ON THIS PAGE
None.
ON THIS PAGE
