hwIPPTPublish SetDestination
Sets the destination/location to publish the session.
hwIPPTPublish_handle SetDestination type
HyperWorks Tcl Modify
- type
 - The location where you want to publish a session. The session gets published to the
            destined string type. If disk is given as string, then the appropriate
            path should be specified in the SetPathOnDisk command.
- new
 - Session is published to a new PowerPoint file.
 - open
 - Session is published to an opened PowerPoint file.
 - disk
 - Session is published to a specified file on disk.
PPTPublish SetDestination new Error
Returns success (0) or an error code.
Keywords
HyperWorks
Tcl
Query
