hwIProject IsDirty
Checks to see if the session has unsaved data.
hwIProject_handle IsDirty
HyperWorks Tcl Modify
This command checks whether the session contains unsaved data. If the project has unsaved data, then true is returned. If the data has been saved, then false is returned.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj IsDirty
      Error
Success (true or false value) or an error message is return.
Keywords
HyperWorks
Tcl
Modify
