hwITemplex Evaluate
Mathematically evaluates a string and returns the result.
hwITemplex_handle Evaluate myexpression, type
HyperWorks Tcl Query
Returns a string indicating the evaluated output of myexpression.
- myexpression
 - The expression to be evaluated.
 - type
 - If set to ‘true’, ‘template’, or ‘templex’, the expression is evaluated using the Templex language. Otherwise, it is evaluated as a simple math expression.
mySessionName GetProjectHandle myProjectName
myProjectName GetTemplexHandle myTemplexName
myTemplexName Evaluate "1+sqrt(2)" falseErrors
None.
