plt3DIAxis GetScale
Gets the scale type for the axis.
plt3DIAxis_handle GetScale
HyperWorks Tcl Query
Returns a string indicating the scale type for the axis. Options include linear, log, dB, or dB10.
None.
View new features for HyperWorks Desktop 2022.3.
Automate common workflows using the Process Manager.
Determines if autofit is applied to the axis.
Gets the color of the axis.
Gets the spacing between tics for the axis.
Gets the label (displayed text) of the axis.
Gets the maximum value for the axis.
Gets a handle to an hwIFont interface for the label font of the axis.
Gets a named meta-data value previously associated with the axis.
Gets the minimum value for the axis.
Gets the title of the axis.
Gets the number of grids between tics on the axis.
Gets the number of tics for the axis.
Gets the format used for displaying tics on the axis.
Gets the number of decimal places displayed for tics on the axis.
Gets the method used for placing tics on the axis.
Gets a handle to an hwIFont interface for the tics font of the axis.
Gets if the axis is displayed or hidden.
Sets whether autofit is applied to the axis.
Sets the text color of the axis.
Sets the spacing between tics for the axis.
Sets the label (displayed text) of the axis.
Sets the maximum value for the axis.
Associates a named meta-data value with the axis.
Sets the minimum value for the axis.
Sets the title of the axis.
Sets the number of grids between tics on the axis.
Sets the number of tics for the axis.
Sets the format used for displaying tics on the axis.
Sets the number of decimal places displayed for tics on the axis.
Sets the scale type for the axis.
Sets the method used for placing tics on the axis.
Sets whether the axis is displayed or hidden.
None.
