plt3DIBarChart GetSymbolStyle
Gets the symbol style of the bar chart.
plt3DIBarChart_handle GetSymbolStyle
HyperWorks Tcl Query
Returns the symbol style index of the bar chart.
None.
View new features for HyperWorks Desktop 2022.3.
Automate common workflows using the Process Manager.
Returns the bar chart color index.
Gets a named meta-data value previously associated with the chart.
Sets the bar chart color index.
Sets the symbol style of the bar chart.
None.
