plt3DICursor GetBoxColor
Returns the cursor box color index.
plt3DICursor_handle GetBoxColor
HyperWorks Tcl Query
Returns the color index.
None.
View new features for HyperWorks Desktop 2022.3.
Automate common workflows using the Process Manager.
Moves the cursor to the point corresponding to an argument list.
Moves the cursor to the global maximum of one component of the plot.
Moves the cursor to the global minimum of one component of the plot.
Moves the cursor to the local maximum of one component of the plot along an axis.
Moves the cursor to the local minimum of one component of the plot along an axis.
Returns the cursor’s box visibility.
Returns the curve’s highlight state.
Returns the cursor I position.
Returns the cursor J position.
Returns the curve’s color index.
Returns the cursor line’s visibility.
Gets a named meta-data value previously associated with the cursor.
Gets the unique variable name (varname) of the cursor’s parent object.
Returns the cursor’s text visibility.
Returns the curve’s visibility state.
Gets the W value at the cursor location.
Gets the X value at the cursor location.
Gets the Y value at the cursor location.
Gets the Z value at the cursor location.
Sets the cursor i and j position to match the pick point.
Sets the cursor box color index.
Sets the cursor box’s visibility.
Sets the curve’s highlight state.
Sets the cursor I position.
Sets the cursor J position.
Sets the curve color index.
Sets the cursor line’s visibility.
Sets the cursor text visibility.
Sets the auto curve visibility state.
ON THIS PAGE
None.
ON THIS PAGE
