plt3DIPlane GetVisibility
Returns the plane’s visibility state.
plt3DIPlane_handle GetVisibility
HyperWorks Tcl Query
- True
- The plane’s shadow is visible.
- False
- The plane’s shadow is not visible.
None.
View new features for HyperWorks Desktop 2022.3.
Automate common workflows using the Process Manager.
Gets the plane’s base coordinate.
Returns the color of the plane.
Returns the cross section only state.
Gets the current drag location for the plane.
Gets the maximum drag location for the plane.
Gets the minimum drag location for the plane.
Gets the plane’s enabled state.
Gets a handle to an hwIFont interface for the font of the plane's label.
Gets whether a plane is highlighted.
Gets the location of a plane's label.
Gets the plane’s orientation plane.
Sets the current drag location for the plane.
Reverses the current direction of the plane.
Sets the plane’s base coordinate.
Sets the plane’s color index.
Sets the cross section only state.
Sets the plane’s enabled state.
Sets whether the plane is highlighted.
Sets the location of a plane's label.
Sets the plane’s orientation plane.
Sets the plane’s visibility state.
None.
