plt3DIPlot GetSmoothNormals
Gets the state of normal smoothing.
plt3DIPlot_handle GetSmoothNormals
HyperWorks Tcl Query
- True
 - When normal smooth is on.
 - False
 - When set to the default state.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName [myProjectName GetActivePage]
myPageName GetWindowHandle myWindowName [myPageName GetActiveWindow]
myWindowName GetClientHandle myPlotName
myPlotName SetSmoothNormals
Success (0) or an error code.
