pltIBuildPlotsCtrl SelectDataFile
Selects a file to use in build plots mode.
pltIBuildPlotsCtrl_handle SelectDataFile active_file, (post_mode)
HyperWorks Tcl Modify
This command selects a file to use in build plots mode.
active_file
The filepath of the file that you want to use.
(post_mode) (Optional)
True
To open the file in post mode (HyperView).
False
If you do not want the file to be opened in post mode, input false or nothing (this would keep the file in HyperGraph).
hwi GetSessionHandle sess;
sess GetClientManagerHandle mgr plot;
mgr GetBuildPlotsCtrlHandle build;
build SelectDataFile "C:/demos/mv_hv_hg/plotting/madymo/FORCES" false;
Keywords
HyperWorks
Tcl
Build Plots
Modify
