pltICurveComplex GetBarStyle
Gets the bar style of the curve.
pltICurveComplex_handle GetBarStyle
HyperWorks Tcl Query
This method is only valid for bar charts.
Returns the index of the bar style of the curve.
View new features for HyperWorks Desktop 2022.3.
Automate common workflows using the Process Manager.
Adds a new, empty attribute to the curve.
Applies a bridge edit to the curve.
Applies a cut edit to the curve.
Indicates whether to display the curve as a line or a series of bars.
Gets a handle to a pltAttribute interface for the specified attribute.
Gets a handle to a pltEdit interface for the specified attribute.
Gets the highlight state of the curve.
Returns the number of edits in a curve.
Gets the number of points on the curve.
Gets a handle to a pltVector interface for the specified curve.
Applies a hide edit to the curve.
Removes the specified attribute from the curve.
Removes the most recently applied edit from the curve.
Applies a replace edit to the curve.
Sets the bar style of the curve.
Sets whether or not the curve is displayed in the legend.
Sets the highlight state of the curve.
Sets the line color of the curve.
Sets the line style of the curve.
Sets the line thickness of the curve.
Sets the symbol color of the curve.
Sets the symbol frequency of the curve.
Sets the symbol style of the curve.
Sets whether the curve is displayed or not.
Applies a trim edit to the curve.
