pltINote GetBitmap
Gets the filename of any bitmap displayed in the note.
pltINote_handle GetBitmap
HyperWorks Tcl Query
Returns the filename of any bitmap displayed in the note.
Error
None.
View new features for HyperWorks Desktop 2022.3.
Automate common workflows using the Process Manager.
Draws an outline around a note.
Gets the text alignment for the note.
Gets the attachment method for the note.
Gets the index of the curve to which the note is attached.
Gets the expression or the value of the point on the curve to which the note is attached.
Gets the index of the point on the curve to which the note is attached.
Gets the border thickness of the note.
Gets the text color of the note.
Gets the flag for whether this note is linked to a Phase curve.
Gets the flag for whether this note is linked to a Real curve.
Gets the note’s context menu parameter.
Gets the expression for the x value to which the note is attached.
Gets the x coordinate value when the note’s attachment type is “Coordinates”.
Gets the expression for the y value to which the note is attached.
Gets the y coordinate value when the note’s attachment type is “Coordinates”.
Gets whether the animation cursor is always shown.
Gets whether the note color is automatically matched to curve color.
Finds if the note is embedded on a curve.
Gets a handle to an hwIFont interface for the font of the note.
Gets the note’s index.
Gets the title of the note.
Gets the position of a note in a plot client.
Gets the (unevaluated) text of the note.
Gets whether the note is displayed or hidden.
Sets the text alignment for the note.
Sets the attachment method for the note.
Sets the index of the curve to which the note is attached.
Sets the index of the point on the curve to which the note is attached.
Sets the filename of the bitmap to be displayed in the note.
Sets the border thickness of the note.
Sets the text color of the note.
Set the flag for whether this note is linked to a Phase curve.
Set the flag for whether this note is linked to Phase curve.
Sets the expression for the x value to which the note is attached.
Sets the expression for the y value to which the note is attached.
Sets whether to always show the animation cursor.
Sets whether to match note color to curve color.
Sets if the note is embedded on a curve.
Sets the title of the note.
Sets the position of a note in the plot client.
Sets the position of the note.
Sets the unevaluated text of the note.
Sets whether the note is displayed or hidden.
ON THIS PAGE
None.
ON THIS PAGE
