poIAdvancedQuery SetQueryLogic
Sets the query logic to the advanced query.
advancedQuery_handle SetQueryLogic rule
HyperView Tcl Modify
This command sets the rule to the advanced query.
- rule
 - The rule ID in the string format.
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule extreme]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetExtreme "TopN 3"
set advQueryID [client AddAdvancedQuery]
client GetAdvancedQueryHandle advancedQuery_handle $advQueryID
advancedQuery_handle AddSimulations "current" "current"
advancedQuery_handle SetQuery "entity.id entity.value"
advancedQuery_handle SetQueryLogic "[rule_handle GetID]"
hwi CloseStack
This command returns HW_Error, if there is no rule ID available in the
        advanced query.
