GetID
Gets the ID of the best view.
bestview_handle GetID
HyperView Tcl Query
This command returns the ID of the best view.
bestview_handle GetIDErrors
None.
View new features for HyperWorks Desktop 2022.3.
Automate common workflows using the Process Manager.
Activates or updates the view with the current settings.
Clears the entry on SetHiddenSet.
Gets the entity information of the best view.
Gets the radius of the sphere used for focused view modes (transparency).
Gets the set used to hide entities in the model when showing the best view.
Gets the note offset used for notes in screen percentage.
Gets the note position specified in the best view.
Gets the list of available note positions in the best view.
Gets the status of whether or not spot IDs are shown in the note text.
Gets the simulation index used in the best view.
Gets the subcase used in the best view.
Gets the view mode used in the best view.
Gets the list of available view modes that can be used in the best view.
Sets the entity information for the best view.
Sets the radius of the sphere for all focused view modes (transparency).
Sets the set to be used for hiding entities.
Sets the note offset distance from the entity center.
Sets the position of the note for the best view around the entity.
Sets whether or not the spot ID is shown in the note text.
Sets the simulation index to be used for the best view.
Sets the subcase to be used for the best view.
Sets the view mode to be used for the best view.
Updates the view with the current view orientation and note locations.
HyperView Tcl Query
bestview_handle GetIDNone.
