poICrossSectionSet GetID
Gets the cross section ID.
poICrossSectionSet_handle GetID
HyperView Tcl Query
This command retrieves the cross section ID.
Returns the section ID, or Null_ID (0) if an error occurs.
View new features for HyperWorks Desktop 2022.3.
Automate common workflows using the Process Manager.
Gets the entity set information of the cross section for a given entity type.
Gets the IType value of the cross section.
Gets the ITypeID value of the cross section.
Gets the cross section label.
Gets the type of cross section.
Gets the cross section visibility state.
Sets the cross section visibility.
HyperView Tcl Query
