poIFBDCtrl GetTableMode
Gets the current table mode.
poIFBDCtrl_handle GetTableMode
HyperView Tcl Query
This command checks to see if the table mode is enabled.
Returns true or false.
View new features for HyperWorks Desktop 2022.3.
Automate common workflows using the Process Manager.
Creates an FBD cross section.
Deletes a specified FBD cross section.
Gets the output/vector binding of the current request.
Gets the color of a component for forces and moments.
Gets a list of the available cross sections.
Gets the cross section property.
Gets a list of the available cross section properties.
Gets the currently selected cross section.
Gets the values for the currently selected cross section.
Gets the draw position of an FBD vector.
Gets a list of the available FBD vector draw positions.
Gets the draw values for an FBD vector.
Gets the element selection handle for a cross section.
Gets the state of the FBD controller.
Returns whether or not the node selection has been ignored.
Gets the current load type.
Gets the node selection handle for a cross section.
Gets the numeric format.
Gets the numeric format list.
Gets the precision value.
Gets the current reader type/name.
Gets the scale/floating point number.
Gets the state of show prefix.
Gets the size of the sphere for the resultant coordinate location.
Gets the summation point type.
Gets the tolerance value for the controller.
Gets the current display mode.
Gets the display mode list.
Gets the vector head type.
Gets a list of the available vector head types.
Gets the current vector type.
Checks to see if the cross section is valid.
Checks to see if the FBD controller is valid.
Sets the color of force and moment components.
Sets the cross section properties.
Sets the cross sections which need to be evaluated to current.
Sets the draw position for an FBD vector.
Sets the draw values for an FBD vector.
Sets the auto load/unload FBD vector data state.
Sets whether or not the node selection should be ignored.
Sets the current load type.
Sets the numeric format.
Sets the precision value.
Sets the scale value used to display vectors.
Sets the scale mode used to display vectors.
Sets the state of show prefix.
Sets the size of the sphere for the resultant coordinate location.
Sets the table mode.
Sets the tolerance value for the controller.
Sets the vector control display mode.
Sets the vector head type for both Force and Moments.
Sets the current vector type.
ON THIS PAGE
HyperView Tcl Query
ON THIS PAGE
