poIPart GetScale
Gets the scale factors for each coordinate axis.
poIPart_handle GetScale
HyperView Tcl Query
This command returns the scale factors for each coordinate axis.
None.
View new features for HyperWorks Desktop 2022.3.
Automate common workflows using the Process Manager.
Sets the part material to default values.
Gets the part auto color index.
Gets the part color index.
Gets the part default color index.
Gets the part display option setting.
Gets the list of part display modes.
Gets the Euler angles with respect to the transform set by the call to poIModel SetRelativeTo.
Gets the part's ID.
Gets the part's ID visibility.
Gets the part's label.
Gets the internal locator string for a part (for internal use only).
Gets the part material ID (zero if none assigned).
Gets the ID of the material related to a component.
Gets the name of the material related to a component.
Gets the part's mesh mode.
Gets the orientation in the local coordinate system.
Gets the origin with respect to the transform set by the call to poIModel SetRelativeTo.
Gets the ID for the part assembly that contains a component.
Gets the part's parent assembly ID.
Gets the part's polygon mode.
Gets the part's pool label.
Gets the part's pool type.
Gets the position in the local coordinate system.
Gets the ID for the property related to a component.
Gets the positions relative to the parent assembly, local or global.
Gets the shading mode for a specific part and overrides the global setting that was set with poIRenderOptions GetShadeMode.
Gets the part's tracing mode.
Gets the part type's string.
Gets the part's visibility.
Rotates the part about the axis and angle.
Sets the part's auto color index.
Sets the part's color index.
Sets the part default color index.
Sets the part's display mode.
Sets the Euler angles (Z-X-Z) with respect to the system defined by the call to poIModel SetRelativeTo.
Sets the part's ID visibility.
Sets the part's label.
Sets the part's material index.
Sets the part's mesh mode.
Sets the part's orientation in the local coordinate system by the given Euler angles ZXZ.
Sets the part origin in the local coordinate system by the given vector.
Sets the part's polygon mode.
Sets the part position in the local coordinate system by the given vector.
Sets positions relative to the parent assembly, local or global.
Sets the part scale factors for each axis.
Sets the shading mode. This command overrides the global setting that was set with poIRenderOptions SetShadeMode.
Sets the part's tracing mode.
Sets the part's visibility.
ON THIS PAGE
HyperView Tcl Query
None.
ON THIS PAGE
