poIScaleCtrl GetInterpolationScaleMode
Gets the scale mode.
poIScaleCtrl_handle GetInterpolationScaleMode
HyperView Tcl Query
This command returns the scale mode (scale, model_units, or model_percent).
None.
View new features for HyperWorks Desktop 2022.3.
Automate common workflows using the Process Manager.
Copies deformation data to the clipboard.
Gets the name of the nodal vector result that is used for animation.
Gets a list of datatypes suitable for animation.
Gets an analysis system number.
Gets the scale for X, Y, and Z.
Sets a specified data type as a new source for animation.
Sets the scale mode.
Sets the analysis system.
Sets the scale for the XYZ axis.
HyperView Tcl Query
None.
