tblITableEditor AddRule
Adds a rule having empty or default properties and returns the corresponding rule ID.
tblITableEditor_handle AddRule
HyperWorks Tcl Query
Descriptions
Used to add rules for conditional formatting of table cells. It adds a rule having default or empty properties and returns the corresponding rule ID. This rule ID can then be used to get the rule handle. Use the rule handle to set the appropriate rule parameters.
set t [hw::GetT]
set activetableHandle [hwi GetActiveClientHandle ch$t]
set ruleid [ch$t AddRule]
set ruleHandle [$activetableHandle GetRuleHandle rh$ruleid $ruleid]
$ruleHandle SetCellList "A1 A2 B1 B2"
$ruleHandle SetBackgroundColor 3
$ruleHandle SetTextColor 0
$ruleHandle SetValue 10
$ruleHandle SetOperator ">"
$ruleHandle ReleaseHandle
$activetableHandle ReleaseHandle
None.
