txtITextEditor GetRawText
Returns the raw (unevaluated) text.
txtITextEditor_handle GetRawText
HyperWorks Tcl Query
Returns a string indicating the raw text.
None.
View new features for HyperWorks Desktop 2022.3.
Automate common workflows using the Process Manager.
Clears the text editor.
Redraws the text editor.
Evaluates the raw text.
Returns the background color.
Returns the evaluation state of text client text.
Returns the evaluated text.
Gets a handle to the font.
Returns the foreground color.
Returns the name of the text file.
Loads the text from a file.
Refreshes all page areas with the text changes that have been made.
Saves the content of the text editor to a file.
Sets the background color.
Allows you to control the evaluation state of text client text.
Sets the foreground color.
Sets the raw (unevaulated) text.
None.
