vidIMovie GetFilename
Returns the filename of the movie.
vidIMovie_handle GetFilename
HyperWorks Tcl Query
Returns the name of the movie file.
None.
View new features for HyperWorks Desktop 2022.3.
Automate common workflows using the Process Manager.
Returns the number of frames in the movie.
ON THIS PAGE
None.
ON THIS PAGE
