vidINote SetText
Sets the unevaluated text of the note.
vidINote_handle SetText text
HyperWorks Tcl Modify
- text
- The new text for the note.
Success or an error code.
View new features for HyperWorks Desktop 2022.3.
Automate common workflows using the Process Manager.
Gets the text alignment for the note.
Gets the attachment method for the note.
Gets the filename of any bitmap displayed in the note.
Gets the border thickness of the note.
Gets the text color of the note.
Gets a handle to an hwIFont interface for the note font.
Gets the title of the note.
Gets the note position.
Gets the (unevaluated) text of the note.
Gets whether the note is displayed or hidden.
Sets the text alignment for the note.
Sets the attachment method for the note.
Sets the border thickness of the note.
Sets the text color of the note.
Sets the title of the note.
Sets the note position.
Sets whether the note is displayed or hidden.
