Defining the Options of an Analysis
An option is used to customize an entity definition within an analysis. Options can perform operations such as turning entities on or off, or converting joints in an analysis from compliant to non-compliant.
When you select the Options tab on the Analysis panel, a list of the options belonging to the current analysis is displayed. Each analysis has a compliant option by default. This option can be used to toggle the state of joints within the analysis. The joint or bushing within the analysis should be modeled within an *if(Op_Compliant == "Yes") loop in the MDL language using a text editor.
