This tool can bring in a CAD data file into MotionView to create bodies and graphics. The graphics created
are of the type CADGraphics. The CAD file is directly used and components are
represented as Parasolid objects. The mass and inertia properties are calculated for
individual components and this information gets aggregated as the mass and inertia
properties of the body that the components belong to. The Body has their properties set
to get properties from graphics.The steps below outline how to import a CAD
file.
Select the System/Assembly/Analysis into which the geometry is to be imported
(the Model system is the default).
From the File menu, select or click the Import
Geometry icon
on the Standard toolbar to display the Open
dialog.
Select the importing CAD file using the File
selector.
Click Open.
The CAD file is imported. A body and a corresponding graphic is created for
each component in the CAD Part/Assembly.
Note: Steel is the default material
assigned to the graphics. To change materials, select the graphics in the
modeling window and select Material using the
right-click context menu.
