At Reference Signal Value
Captures the value of a given expression when a given reference signal expression achieves a certain value (reference signal value).
![](../../images/post_processing/optimization_wizard_response_types_at_ref_signal_val_panel.png)
Figure 1. Response Type – At Reference Signal Value
Input | Description |
Response Expression | The function that is to be computed. |
Reference Signal Expression | The function at which the Response expression is desired. |
Reference Signal Value | A value of Reference Signal Expression at which Response expression must be computed. |
Reference Signal Tolerance | A small interval around the desired Reference Signal Value required for computation. |
In the above example, the response variable captures the value of the expression that measures difference in YAW positions when the Reference signal (measuring angular rotation between 2 markers) value is zero.
