The main types of outputs that can be defined using output requests are displacement,
velocity, acceleration, and force. In addition to these, more complex outputs can be
extracted using the Expressions and User-defined output types. The output request plays a
very important role in post processing the results from a solver run. Output requests also
pave the way for signal processing of data that is generated by a multi-body
simulation.
If the Outputs panel is not currently displayed, select the desired output by
clicking on it in the Project Browser or in the modeling window.
The Outputs panel is automatically displayed.
From the Result Type drop-down menu (the topmost menu), select the type of
results that need to be extracted.
Select an output method from the second drop-down menu.
There are three main ways to define displacement/velocity/acceleration outputs
between any two bodies:
There are two methods of defining a force output:
