Scooter - Trailing Arm - Mono Shock
This suspension uses a single shock absorber connected between the rear trailing arm and the frame. The trailing arm front end is pivoted to the frame and other end is attached to the rear wheel.
![](../../images/post_processing/rear_monoschock_swng_arm_susp.png)
Figure 1. Rear Monoshock Trailing Arm Suspension
Model Use
The Rear Monoshock Trailing Arm Suspension system can be used in Rear half vehicle or full vehicle models of a two-wheeler. The default geometry and mass approximate that of a two-wheeler scooter, but the model and data can be revised to reflect any size two wheeler.
- The wheel body represents the mass and inertia of the tire and the rim.
- The wheel hub body represents the mass and inertia of other rotating bodies such as a brake rotor. The wheel hub and brake rotor have no associated graphics.
- The wheel and wheel hub parts use the Wheel center location as the center of gravity.
The image below shows the Project browser view of the systems on a fully populated rear suspension model. The Rear Monoshock Trailing Arm system has three “child” systems.
![](../../images/post_processing/rear_monoschock_swng_arm_susp_browser.png)
Figure 2. Browser View of Rear Mono Shock Trailing Arm Suspension
Points
![](../../images/post_processing/rear_monoschock_swng_arm_susp_points.png)
Figure 3. Principal Points – Rear Mono Shock Trailing Arm Suspension
Bodies
![](../../images/post_processing/rear_monoschock_swng_arm_susp_bodies.png)
Figure 4. Bodies – Rear Mono Shock Trailing Arm Suspension
Joints
Label | Type | Body 1 | Body 2 | Point | Notes |
Frame Swingarm Attachment Joint | Revolute | Swing Arm | Frame | Frame steering Att Point | |
Swingarm Spindle Att Joint | Fixed | Spindle | Swing Arm | Rear Wheel Center | |
Spindle to Wheel | Revolute | Rear Wheel | Spindle | Front Wheel Center |
![](../../images/post_processing/rear_monoschock_swng_arm_susp_bushings_joints.png)
Figure 5. Joints - Rear Mono Shock Trailing Arm Suspension
