.hist file
The .hist file is an OptiStruct ASCII format results file.
File Creation
This file is created when an optimization is performed. Creation of this file is controlled by the I/O Option DESHIS.
File Contents
This file contains the iteration history of the objective function, maximum constrain violation, design variables, DRESP1 type responses, and DRESP2 type responses. Contents of this file are controlled by the I/O Option HISOUT.
File Format
The section outlines the format of the .hist OptiStruct ASCII file.
| iteration | Objective | Max_Const_Violation | Design_variables | DRESP1s | DESP2s | |||
- Data
- Description
- iteration
- Iteration number.
- Objective
- The value of the objective function.
- Max_Const_Violation
- Maximum constraint violation in %.
- Design_variables
- Value of the design variables. Each design variable is given its own column.
- DRESP1s
- The value of the DRESP1s. Each DRESP1 type response is given its own column.
- DRESP2s
- The value of the DRESP2s. Each DRESP2 type response is given its own column.
- The value of each design variable, DRESP1 response and DRESP2 response, is provided in its own column.
