RD-HWX-T: 1000 Tensile Test Setup
This tutorial demonstrates how to simulate an uniaxial tensile test using a standardized specimen with a defined cross-sectional area which is stretched until fracture.
![rd3500_01](../../../images/solvers/rd3500_01.png)
- Step1: Load the Radioss (Block) interface and load initial solver deck
- Step 2: Define material
- Step 3: Define property
- Step 4: Create rigid body
- Step 5: Create boundary conditions
- Step 6: Create imposed velocity
- Step 7: Create output (time history / anim)
- Step 8: Create Engine setup and export the model
- Step 9: Run the model using Compute Console
- Step 10: Post-process with HyperView and HyperGraph
Model Description
- UNITS: Length (mm), Time (ms), Mass (kg), Force (kN) and Stress (GPa)
- Simulation time D01 [0 – 40.]
- At the right side, a constant velocity is applied = 1 mm/ms on -X direction.
- Tensile test object dimensions = 12 x 200 with a uniform thickness = 1.7 mm
- Material
- Value
- Initial density, [Rho_I]
- 2.7e-6Kg/mm3
- Young's modulus, [E]
- 60.4 GPa
- Poisson's ratio, [nu]
- 0.33
- Yield stress, [SIGMA_Y]
- 0.09026 GPa
- Ultimate tensile stress, [UTS]
- 0.175 GPa
- Engineering strain at UTS, [E_UTS]
- 0.24
- Failure plastic strain, [EPS_max]
- 0.75
Prerequisites
To run this simulation, you will need access to a licensed version of Radioss. You will need an internet connection to watch the video tutorials and download the files.
