User Failure Models
In Radioss up to 3 user’s failure models (USER1, USER2, and USER3) can be defined for shell and solid elements.
User’s failure model for beam and truss are not yet available.
- The Starter subroutine is called lecr04, lecr05, and lecr06 and is used to read the failure data model and to initialize failure material parameters
 - The Engine subroutine for solids is called f04law, f05law, and f06 law and is used to compute failure criteria at an integration point. The corresponding shell subroutine is called f04lawc, f05lawc, and f06lawc
