Altair Inspire User Guide
2022.3
  1. Home
  2. Reference
    View the glossary, frequently asked questions, and errors and alerts.
  3. Errors and Alerts
    Altair Inspire checks for potential problems with the model before running an analysis or optimization and will suggest solutions when problems are found.
  4. Motion Errors and Alerts
    View suggested solutions for resolving Motion errors.
  5. Modeling Errors and Alerts
    The section contains information about how to resolve modeling errors in Inspire Motion.
  • What's New
  • Get Started
  • Tutorials
  • Parametric Modeling
  • Structures
  • Motion
  • Fluids
  • Design Explorer
  • Manufacture
  • Print 3D
  • Inspire Python API
  • Reference
  • Keyboard Shortcuts and Mouse Controls
Index
2022.3
  • What's New
    Discover new features and enhancements.
  • Get Started
    New to Inspire? Learn the basics here.
  • Tutorials
    Start using Inspire with our interactive tutorials.
    Create parametric sketches, geometry, and PolyNURBS with construction history and variables.
  • Structures
    Set up your model and run a structural analysis or optimization.
  • Motion
    Set up and run a motion analysis, plot the results, and export the results.
  • Fluids
    Prepare and run a computational fluid dynamics simulation.
  • Design Explorer
    Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method.
  • Manufacture
    Set up and run a basic porosity or thinning analysis.
  • Print 3D
    Prepare and run an additive manufacturing simulation, and export a file for 3D printing.
    Learn how to access the Inspire Python API including online help, quick start demos, and the Extension Manager.
  • Reference
    • Frequently Asked Questions
      Got questions? We have answers!
    • Troubleshooting
      Need help troubleshooting a problem? Check out our troubleshooting topics.
    • Errors and Alerts
      • Inspire Errors and Alerts
        There are a number of problems that can prevent analysis or optimization from running successfully. The most common reasons for failed runs are improperly defined load cases.
      • Motion Errors and Alerts
        • Modeling Errors and Alerts
          • Model Contains No Active Parts
          • All Parts Are Grounded
          • Massless Part(s) Detected
          • Directional Conflict in Torsion Spring
          • Directional Conflict in Motor
          • Motor or Actuator Joint is Locked
          • Parts Defining Torsion Spring Are Grounded
          • Coil Spring Dimensions Are Not Realistic
          • Error Importing .csv File
          • Coupler Requires Joints to be Rigid and Active
          • Invalid Coupler
          • Actuator Joint Type Is Incorrect
          • Microseconds Time Units Not Supported for Motion Analysis
        • Run Termination Errors
          This section contains information about how to resolve run termination errors in Inspire Motion.
        • Information and Alerts
          This section contains information and question alerts in Inspire Motion.
    • Glossary
      View a list of glossary terms and definitions.
    Learn keyboard shortcuts and mouse controls for common operations.
2022.3
  1. Home
  2. Reference
  • What's New
  • Get Started
  • Tutorials
  • Structures
  • Motion
  • Fluids
  • Design Explorer
  • Manufacture
  • Print 3D
  • Reference
Index
  • Invalid Coupler
