Predict Trim Line
From the Tryout ribbon, click the Predict icon.
Click the Trim Line icon.
Select lines that you would like to predict trim lines for.
- Optional:
Select Replace Trim Lines to automatically replace existing trim lines with
predicted trim lines.
Note: You must have a single trim operation and a single trim line to use the replace option.
Click
Predict.
Manually Replace Trim Line with Predicted
Click the Trim icon in your Operations.
On the secondary ribbon of tools that appears, click the
Trim icon.
Select the trim line that you would like to replace.
Click
to remove the selection.
Select the new predicted trim line and click
Assign.
