Advanced Screen Capture
Record a video or take a snapshot of a specific area or the full screen with the current background.
- Select .
Configure the settings:
In the microdialog, click Settings
and configure the screen capture settings,
which apply to both snapshots and videos.
Define the capture area:
- To capture a specific area of the screen, click Select Screen
Area
, and then drag to draw a box. - To capture the full screen, click Select Full
Screen
Area
Capture the screen:
- To take a snapshot, click Take Snapshot
. - To record a video, click Start/Stop Recording
, manipulate the model as desired, and then
click Stop Recording
Depending on what option was selected in the Screen Capture Settings, either the Save As window will appear or the captured image/recording will be saved to the default file location.
The snapshot is saved as a .png file. Depending on the File format defined in the Video Settings, the video is saved as a .mp4 or .gif file.
Configure the screen capture settings.
- Include mouse cursor
- Select this option to include the mouse cursor when recording a video or taking a snapshot of the screen.
- Copy image to clipboard
- If selected, the image is copied to the clipboard and is available to the other applications.
- Show file save dialog
- If selected, the save file dialog is shown when saving an image or recording. The last selected location is remembered throughout the session.
- Save to a default file location
- Select this option to automatically save the video or snapshot to a default
location. The default location is
Documents/Altair/captures
To change the default location, click Select save location
, and then select a folder. - Capture delay (sec)
- Define the number of seconds that elapse before the video starts recording
or the snapshot is taken.
The default delay time is 3 seconds.
- Frame rate
- Define the number of frames displayed per second in the video.
The default frame rate is 24.
- File format
- Save the video as a .mp4 or .gif file.
