Define parameters and execute an analysis to understand filling, packing, cooling or warpage events during molding.
Generate results for individual or combined events.
View the status of the current run, as well runs for the current model that have not yet been viewed. To see all past
runs, you need to view the run history.
Note: Detailed analysis is available only in the Advanced
ribbon.
Run Analysis
Define parameters and execute an analysis to understand filling, packing, cooling or warpage events during molding. Generate results for individual or combined events.
Add Fiber Orientation Results
Select Add Fibers when running a detailed filling analysis to produce results that include fiber orientation tensors.
Animate and Record Results
Use the Animation Toolbar that appears at the bottom of the modeling window to animate and record results.
Run Status
View the status of the current run, as well runs for the current model that have not yet been viewed. To see all past runs, you need to view the run history.
Run History
View, sort, open, and delete past runs for the current and previous models.
